AEG LAV72630 sn: 91400209601
Called to this machine for a draining fault, customer said had seen a fault code.
I put the machine in to diqgnostic mode to access the code which I found was E20 (not draining).
When I went to to take machine out of fault code, no matter what I do the numbers in the dial just count down in 1 second intervals!
This appears to be a software problem to me, has anyone else seen this before after accessing the diagnostic mode?
thanks
