AEG LAVAMAT 14850 NOT DRYING
Home Forums Public Support Forums Help And Support Washing Machine Help Forum AEG LAVAMAT 14850 NOT DRYING
  • #68516
    Miklinz
    I have a lavamat 14850 and it’s not drying, the washing is coming out hot and still wet.
    The fan looks like its functioning fine, but in the back on the left under the fan, is a clear plastic flat piece about 5-7″ wide 1/2-1″ deep and runs about two thirds the away down the inside the machine and then attaches to a rubber pipe. This clear piece looks full of fluff.
    I’m wondering how this piece can be removed to be emptied. It looks a very awkward process for something that seems like it should be a regular part of the basic maintenance.
    Any help would be really appreciated. Oh and it’s 2 and a half yrs old and been great till now.
    #371389
    captaincaveman1
    Re: AEG LAVAMAT 14850 NOT DRYING
    You have to remove fan assy completly undo the heater box and push it away toward the soap draw undo the bottom hose the drain hose and where it connects onto the pump manifold and with a struggle it is just possible to remove it from the top but the syptoms you have can also be due to the coil on the inlet valve being open circuit
