Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › AEG Lavamat 16810 – all programs terminate with time To end going to 3 Minutes
- This topic has 21 replies, 4 voices, and was last updated 6 years, 10 months ago by
baggy99.
May 30, 2019 at 9:52 am #461719
baggy99
ParticipantDave – thanks, that was a great idea (dunno why I didn’t think if it!) The resistors are all 1k, so that’s an easy fix. Triac on order, so we’ll see if I can get it to live again.
Iadom – thanks. I come from a TV repair background where we used to repair stuff to component level, and all manufacturers used to issue detailed circuit diagrams. I just assumed white goods would be similar!
Is there any reset procedure after applying the fixes, or will it just work, assuming I’ve tracked down all of the faults? I ask because the machine used to go through 4-5 mins of the cycle before dropping to “3 minutes”, (see my OP), but it now jumps straight to 3 mins, immediately after pressing start. I don’t think I changed anything, apart from running the error check program and blowing the motor completely when I hard-wired it (it had seized solid – blew the windings when hard-wired).
May 30, 2019 at 10:06 am #461720iadom
ModeratorNo reset as such, there is a procedure to erase the last known error from memory but there should be no need to do that.
May 30, 2019 at 10:21 am #461721baggy99
ParticipantOK, thanks
June 4, 2019 at 3:27 pm #461722baggy99
ParticipantMany thanks all. Machine now running again. I had to change the triac, the associated 1k resistor, the 220 ohm gate feed resistor, the darlington pair chip and of course the pump – basically everything forward from the micro, but at least that survived. It’s just done a full cycle wash and is almost good as new! Many thanks for all the help.
June 4, 2019 at 3:39 pm #461723iadom
Moderator[IMG2=JSON]{“data-align”:”none”,”data-size”:”full”,”src”:”https://www.ukwhitegoods.co.uk/forums/core/core/images/smilies/thumbsup.gif”}[/IMG2] Thanks for letting us know. 🙂
September 25, 2019 at 8:06 am #461724oscar123
ParticipantThanks for the tech info very much appreciated.. Last error was EF5. Run the machine empty and it spun no problem. Put a good size load in and it wouldn’t spin.. put more load in and tried again very patiently :confused:… No spin. Motor or control board? gut says board so one order but if there is a way to check for sure it would be appreciated..
September 25, 2019 at 8:41 am #461725electrofix
Moderatoroscar123 wrote:Thanks for the tech info very much appreciated.. Last error was EF5. Run the machine empty and it spun no problem. Put a good size load in and it wouldn’t spin.. put more load in and tried again very patiently :confused:… No spin. Motor or control board? gut says board so one order but if there is a way to check for sure it would be appreciated..
have you replied to the wrong thread ?
should this be here
https://www.ukwhitegoods.co.uk/forums/forum/trade-member-forums/trade-technical-spare-parts-forums/trade-technical-enquiries/851908-zwf91483w-zanussi-lindos-no-spinDave
