Hi, my 5 year old AEG Lavamat 16810, is gone BAD. 👿
As soon as I turn the dial the machine starts – even with the door open. Or at least it sounds like it is starting a wash, it may be the drain pump running?
If I actually start a wash, (door closed!) water drains as it is filling so machine never fills and cycle doesn’t progress.
Drain and Spin programs work OK.
Any idea if this is likely to be a pump problem or a control or power pcb problem? And likely repair costs of either?
Any suggestions gratefully accepted.
Thanks in advance.
