AEG Lavamat 50420
  • #47381
    M1
    AEG Lavamat 50420 goes through complete wash but won’t spin (carbons Ok)
    Wait 10 mins -to 15mins and select spin and machine will spin, but the machine allways seems to spin, if spin selected on its own and it has not just done a complete wash.
    All valves are OK, no burn marks on PCB/timer.
    Any ideas (apart from the obvious timer fault)
    #293297
    martinm
    Re: AEG Lavamat 50420
    if water is emptying quick enough and pressure bottle clear then youd have suspect motor overheating ant cutting out on its own toc
    #293298
    M1
    Thanks for the reply martinm,
    I have tested the motor when it won’t spin and there is no open circuit therefore if there was a cut out internally in the motor it would go O/C if the motor was overheating.
    Useully there is a NTC in line with the Triac on the PCB, could this have a faullt and not working properly I am tempted to change it !
    Any thoughts ???
