AEG Lavamat 50435W PNC 91400218600
Home Forums Trade Technical & Spare Parts Forums Trade Spare Parts AEG Lavamat 50435W PNC 91400218600
  • #48184
    mike100
    Does anyone know where I can get a spider for the machine.
    All I can get coming up is drum complete 1320045162.
    There must be a pattern someone does hopefully.
    Mike
    #295883
    Re: AEG Lavamat 50435W PNC 91400218600
    Mediator says it’s “obsolete” and advises that complete drum is the only way 🙁 . Could be that some supplier or other still has the old part. Picture looks like the ordinary Zanussi type but you can never be sure with these AEGs. Have had to BER one or two myself. You might be able to get a clue from the bearing sizes if you can find them out. Only other way is to dismantle machine, taking standard spider with you and just make a labour charge if it doesn’t fit. Or maybe it’s worth the price to the customer to get a good machine going again.
    Mike.
    #295884
    aqualectric
    Bearings are 6205ZZ and 6206ZZ (50061408006 and 50653825005) – not the standard 6206 and 6207 supplied in the large bearing Zanussi kit. Seal is 1249685007. Spider outgoing part number was 1320045139 which now cross – references with the drum assembly you have found. (1320045162). The spider was not a standard ‘large bearing’ Zanussi spider.
    Looks like it’s only available as one assembly now…..good old wasteful Electrolux…… 👿
    Steve.
