AEG Lavamat 50630, 914-002-185 Overheats water, cause?
Home Forums Public Support Forums Help And Support Washing Machine Help Forum AEG Lavamat 50630, 914-002-185 Overheats water, cause?
  • #75029
    gf15
    Hi All,
    First post 😀
    Our AEG Lavamat 50630 which is about 10 years old has started to overheat the water to such an extent it has deformed the soap drawer.
    Is it something as simple as the thermistor or thermostat that has failed?
    Does my machine have both?
    To test, is it a case of measuring the resistance across the terminals of thermistor, and if it changes from ~1 Ohm to a higher resistance when placed in hot water it is working OK?
    For this machine is the heater element thermistor accessed from the front or rear?
    For this machine is the Thermostat accessed from the front or rear?
    All replies gratefully received!
    Garret
    #393656
    Re: AEG Lavamat 50630, 914-002-185 Overheats water, cause?
    Thermistor needs replacing. Fitted into the heater element and easy to replace. Also check that the connector plug is OK as that can cause same symptoms. Access via rear panel removal.
