AEG Lavamat 6100 Digitronic Drum Bearings
Home Forums Public Support Forums Help And Support Washing Machine Help Forum AEG Lavamat 6100 Digitronic Drum Bearings
  • #50717
    littleredrooster
    We have an elderly 6100 which now has very noisy drum bearings. Is this a reasonably easy DIY repair (I am a well-qualified engineer) or should I just bite the bullet and buy a new machine? (I replaced the motor brushes just a couple of weeks ago and the rest of the machine is good, despite it being 15+ years old)
    Would the bearings be available at my local bearing supplier or are they ‘specials’?
    Anyone got a step-by-step guide, please?
    Many thanks for any help.
    #305711
    Re: AEG Lavamat 6100 Digitronic Drum Bearings
    Bearing amnd seal set HERE.
    Possibly the easiest bearing change ever – motor and pulley off, three bolts for the bearing housing to undo and it all pulls out backwards. Then out with the big hammer and drift.
    littleredrooster
    My grateful thanks to Mr Penguin for a speedy, concise reply. I will be going forth tomorrow with my Birmingham screwdriver! 🙂
    #305713
    littleredrooster
    OK – motor off, all bolts out, but the three-legged ‘spider’ will not draw off the drum shaft.
    Does it just need more violence, or is there summat I’m missing?
    Should I be doing this with the machine upright, or should I lay it on its face so the shaft is upright? What will support the inner drum once I get the ‘spider’ off?
    #305714
    littleredrooster
    Ha! Done it – more violence was all that was needed. 🙂
    Bearings popped out nice ‘n easy, too.
    #305715
    Well done. Bit of a physical job, but very satisfying.
    littleredrooster
    Righty-o! Back again!
    All back together with new bearings and seals but the drum goes tight when I tighten the pulley centre-bolt. It’s almost as if it’s now rubbing on a build-up of calcium (of which there was quite a bit around the front of the seal).
    How can it now be in a different (relative) position? Does not compute?? The spider is non-adjustable (isn’t it?), so the confounded thing MUST be in the same place as it was, but it rubs from (apparently) somewhere in between the inner and outer drum.
    WTF?? Any ideas, good people?
    #305717
    TheSpinDoctor
    Hi.
    What condition was the drum shaft in?
    #305718
    littleredrooster
    TheSpinDoctor wrote:Hi.
    Shaft was good. I dressed it with some 240 wet&dry, then 1200 to polish the seal surface, then put a bit of grease on all surfaces before assembly. I’m fairly sure that the inner bearing is down onto its shoulder and not binding, so the drum must be in the same position as it was.
    Puzzled? Moi?
    #305719
    One of your bearings isn’t fully driven home.
