AEG LAVAMAT 61300W
  • #64590
    funkyboogy
    PNC 914001129
    appliance wont switch on at required prog setting
    ie set to quick wash and nothing happens – move dial on 2 clicks and it will start ..
    does this on most other settings .. i think timer /pcb prob
    anyone seen this ..
    cheers ally
    #357492
    Re: AEG LAVAMAT 61300W
    you fault descrition is a bit wooly
    you then rotate dial 2 clicks clockwise and it will ( what prog is this ?)
    you can set it on any programme and it wont start but if you move it 2 clicks it will ?
    did have a look got no service info for this machine exept wiring diag and what is labelled a training manual
    i would check
    water valves
    soap draw unit. This machine should have a motorised soap draw the moves to allow water to go into correct compartment if it has check motor has not failed as it wont start unless motor is in correct position for the set programme
    funkyboogy
    CHEERS ..
    what i meant was if you start it on quick wash .. it doesnt do anything … but if you move timer 2 clicks forward it will start filling etc ..
    appliance doesnt seem to want to start at proper settings –
    – i didnt see motor on soap drawer – but did check valves – heater etc .. they were ok ..
    cheers ally
    #357494
    this is a long shot
    if you look up timer for PNC 914001129 00 and timer for
    PNC 914001129 01 they come out to the same number although they were not when they were built
    the 01 model does have a soap draw motor unit whereas the 00 unit does not. so there must be a plug on the timer to blank out this option on the 00 model which i am assuming yours is. If this plug has dropped off or is not making contact the result will be the timer will stop as yours does as it wait for the signal to fill. may well be the wire that now feeds the valves
    as i say long shot but worth a punt
    funkyboogy
    cheer mate will have another look … dont do much of these aeg,s ..
    ally
    #357496
    This is one of the older ones.
    new ones are a Zannussi revamp and not as good
    if you want what little info i have let me have an email address
    #357497
    Criscold
    If I remember correctly on these – the knob comes in two parts that clip together and I don’t now if it possible for the parts to become out of line
    Colin
