Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › AEG lavamat 62820 What is a “barrel ring”?
- This topic has 7 replies, 5 voices, and was last updated 16 years, 6 months ago by
leavemetogetonwithit.
September 29, 2009 at 8:26 pm #48951
ParticipantGoing to size this one up tomorrow. Sounds like bearings, possibly also shaft. Had a look at the exploded on mediator, spider’s obsolete 😯 ? but between it and the bearing seal is a small round part described as “barrel ring” ❓ OPN = 1100991106 Only thing I can imagine it being is the brass ring on which the bearing seal runs. Not come across this before.
Ah, just googled and found a picture on the french e-bay site. Definitely is the brass ring. Supplied together with a packet of loctite 242. Is it threaded on? I presume I’ll need a blowlamp? Anybody know?
Mike.September 29, 2009 at 8:30 pm #298279Jonah
ParticipantRe: AEG lavamat 62820 What is a “barrel ring”?
Sell em a new ISE10 Mike, less hassle mate 😉
September 29, 2009 at 8:52 pm #298280leavemetogetonwithit
It’s on the cargo boat to the Scillies. They reckon’ they don’t want to have to get a new one as the room it’s in doesn’t have a big enough door.
I’m quite looking forward to changing a barrel ring, anyway. Make a nice change from sending it to landfill.
Mike.September 30, 2009 at 7:28 am #298281Jonah
Nice one Mike, you really get the different jobs down there!!
Seriously I haven’t seen one so can’t help out but good luck anyway mate 🙂September 30, 2009 at 7:34 am #298282clivejameson
I’ve never changed one before…always had a complete spider, but apparently the way to remove the old one is to attack it with a centre punch all around it which distorts it slightly and breaks the adhesive. 😉
September 30, 2009 at 10:19 am #298283Phidom
The only washer I’ve repaired on a boat was on a fishing trawler called the “Genesis”. Some of you may have seen said boat on TV in the “Trawlermen” series.
September 30, 2009 at 10:52 am #298284electrofix
ModeratorRe: AEG lavamat 62820 What is a “barrel ring”?
worst thing about ships is a lot of them use 60hz and out parts dont like it
September 30, 2009 at 10:53 am #298285leavemetogetonwithit
Went to have a look this morning. Sadly it feels like I will only need the bearings, not worn enough to have damaged the ring. Too many mechanics on board must have noticed the noise. Also won’t get a free trip to the isles as they’ll be in dry dock for the next couple of weeks 😥 .
Barrel ring is in stock at Lux for £10.45 if anyone ever reads this in search of one.
Thanks for the help, guys.
Mike. -
