aeg lavamat 6350
  • #8671
    scotport
    Machine will fill wash but not pump water out of drum.
    What would be estimated cost of repair?
    Or would you advise new machine?
    #129904
    Dave_Conway
    Re: aeg lavamat 6350
    If it’s not draining it could be a simple blockage or the drain pump has failed.
    Have you checked the filter ?
    #129905
    scotport
    Yes filter clear. Cannot hear pump running when drain selected.
    #129906
    scotport wrote:Yes filter clear. Cannot hear pump running when drain selected.
    Can you rotate the pump impellor behind the filter then? It should turn quite freely!
    scotport
    Yes. It can turn freely.
    #129908
    Dave_Conway
    Well, as long as there are no blockages anywhere then it can only be the pump 😉
