AEG Lavamat 64810 washing machine
Home Forums Public Support Forums Help And Support Washing Machine Help Forum AEG Lavamat 64810 washing machine
  • #91769
    DaveSB
    The green door light stays on even though the door is properly closed and so the programme won’t start. The problem started with the light flashing red and so I replaced the Interlock mechanism. After which I simply have the green door light and no further response. All the lights of the programmes light up as they should. Any help greatly appreciated
    #449194
    1totalshambles
    Re: AEG Lavamat 64810 washing machine
    Thanks for the model number but to identify this machine it is based on the pnc or product number beginning with 914. So basing this as a 914524150/00 ( a guess out of 12 other versions! ) I would check the motor brushes before doing anything else A great many of these machines are wired through the motor so if there is a fault e.g. worn out brushes the contraption won`t start.To add to the fun and games there might be 2 types ( could be more ) for 3 differing motors 1) ceset motor and 2) the more common Sole or look a like sole motor: both the ceset and sole brushes look entirely different from each other so that`ll help you but there are 2 sole type brushes 1) tag comes out from the top of the brush ( most commonly seen part 4006020152 or alternatives from w/pool/ hotpoint ) and 2) one that comes out from the side part 50265481007. Typically.via AEG site the motor brushes will not be listed as a spare part because of the confusion over motors. Go on to this website`s spares dept and track them down via pictures or if in doubt with the info gleaned from the motor ask them or post a picture to them!
    #449195
    Antdy
    I found worthwhile to call an experienced electrician in Johannesburg .
    #449196
    DaveSB
    Thanks 1totalshambles, You’re right a about model number number it is 914524150. I copied down the wrong number obviously. And thanks for the advice, I’ll get onto it and see what I can do. Much appreciated help
