AEG Lavamat 660 extra rinse
  • #16557
    Sparkcymru
    Old AEG lavamat 660. does anyone know if this has an extra rinse that can be activated. customer says it does but you have to do it inside the machine but doesn’t know how??
    Any help appreciated
    Steve
    #170386
    Dave_Conway
    Re: AEG Lavamat 660 extra rinse
    If you can get the Enr I can check the tech info on this for you, personally I’ve not heard of such an internal “tweak” but you never know 😉
    #170387
    Take the soap drawer out – there should be a little slider switch bottom left of the opening. Small screwdriver required to flip it across.
    Sparkcymru
    theres no soap drawer lever on this one i think that applies to the earlier version of this model. enr is 605611902. I’m going to this machine Sat. so will have a good look at it.
    Steve
    #170389
    Dave_Conway
    Nothing on the tech side or the parts diagram, a DIP switch on the module maybe ?
    #170390
    Sparkcymru
    ok well the modules gotto come out cause it needs sending for repair so i’ll have a good look at it and inside when i get there. Cheers
    Steve
