AEG Lavamat 720 Drain Pump leaking
Home Forums Public Support Forums Help And Support Washing Machine Help Forum AEG Lavamat 720 Drain Pump leaking
  • #22314
    kdh
    I have an AEG Lavamat 720 (E-Nr.605.630306) which leaks from where the two parts of the drain pump screw together. The washer looks undamaged. I’ve been quoted over £100 for a replacement! Is there an alternative fix?
    #194460
    Re: AEG Lavamat 720 Drain Pump leaking
    kdh wrote: Is there an alternative fix?
    I’m almost certain a PMP77 will fit? If you email spares@ukwhitegoods.co.uk they might be able to confirm for you? 😉
