Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › AEG Lavamat 72600 Error CE
- This topic has 4 replies, 3 voices, and was last updated 20 years, 4 months ago by
manic4surf.
November 29, 2005 at 1:42 pm #13677
manic4surf
ParticipantThis machine is displaying CE and the mainwash, rinse and rinse hold LEDs are flashing
The machine was running over night and was full of water when I checked in the morning 😥
Only had time to have a quick play but it seems that the only function that it will perform is pump out
I will have a better look tonight and get the serial number!
I am an electronics eng by trade (more test equipment than washing machines 😀 )
Thanks in advance for your help…
November 29, 2005 at 2:16 pm #156092Dave_Conway
ParticipantRe: AEG Lavamat 72600 Error CE
From inside the door/rating label can you post the PNC (product code) please.
November 30, 2005 at 4:06 pm #156093manic4surf
Not sure what no you refer to so:
Typ: B46 A ED3B 03A
E-NR: 914.001 128
F-NR: 117/229770A bit more information…
I tried running the machine again on a short spin – pump ran, drum didn’t.
Then after the timer had counted to zero it came up with C9 + pre-wash & rinse hold LEDs flashing
Now the error will not clear, even after un-pluggingCorrect me if i’m wrong but it sounds like a motor related problem from previous threads
November 30, 2005 at 4:16 pm #156094Martin
manic4surf wrote:Correct me if i’m wrong but it sounds like a motor related problem from previous threads
Your conclusion is correct and I seriously recommend you seek help by clicking the Repairs@ link below….
December 12, 2005 at 10:05 pm #156095manic4surf
Checked out the motor…
brushes, tacho and windings continuity all OK (loads of meat left on the brushes and it’s about 10 years old)Removed the controller PCB and found copper pad around one of the relays had burnt away (probably as a result of a dry joint)
Reflowed the joint…put it all back together…Same error C9…to clear this I put the machine into the diagnostic mode described elsewhere in this forum them then switched it out again….
Code cleared and machine back to normal….wife happy once more!!
