AEG Lavamat 72630 not working
Home Forums Public Support Forums Help And Support Washing Machine Help Forum AEG Lavamat 72630 not working
  • #96533
    Jor Barrie
    Hi, my AEG Lavamat 72630 stopped early on during a washing cycle, and now (after emptying it and starting fresh) when I try to start it, all the right lights come on, the door locks, but nothing happens. I tried the reset procedure but that didn’t have any effect. The filter is clean and I’ve used the little hose at the bottom to empty it.
    PNC 914 002 096 01
    S-no 108 466 52
    Typ 47A cd ca 10A
    Any help very much appreciated!
    Jor.
    #463739
    well at 19 years old its doing well
    first thing I would check would be the motor brushes
    Jor Barrie
    Update: I seem to have solved the problem by blowing through the drain pipe… It must’ve been blocked somehow?
    #463741
    Jor Barrie
    electrofix wrote:well at 19 years old its doing well
    Thanks for the advice, Dave! I changed the motor a few years ago and the brushes were still fine, but I seem to have solved the problem by blowing through the drain pipe…
    #463742
    Jor Barrie
    Oops, with 47 minutes to go, the machine has now stopped…
    #463743
    any fault codes ?
    Jor Barrie
    electrofix wrote:any fault codes ?
    No, nothing! I’ve re-started the machine and it’s still going although the display was stuck at 47 minutes again for a long time before starting to count down again.
