E-Nr.914001025, F-Nr. 116/738164 is sometimes dead and sometimes work. I did check the wires and source (5 volts and 12Volts) from the main electronic the and even is dead they are OK.( I mean dead when do not start the front panel lights nor the programm)
Any suggestion or service manual will be usefull : ❓ 💡 😳
Thanks Martin,
The problem is solved… It was simply three wires band which connect the program selector and rinse-water level switch(under the detergent compartment) who was wrongly assembled(cought between detergent compartment and metalcase) and makes ground. 😛
