Re: AEG Lavamat 76810 – E50 error
Many thanks for the advice. I’ve tried to get the motor out to check the brushes, but although I’ve removed the four screws holding the motor under the drum, it won’t shift. is there something I’ve missed? I also saw some advice on older AEGs about how to get further details on the problem by pressing two buttons at once. i tried it and the display comes up with E52. can you identify whether it is motor/brushes/inverter or PCB from this? many thanks!
