I have E70 followed by 7 beeps, I see reading old posts this could either be an NTC thermistor or Brushes/motor.
The machine does run, it just displays that error and beeps all the time. Even after turning it off and starting again within 20mins is back to the same thing.
Could you piont me in the right direction please.
Thanks Dave.
So If I meter out the cables from NTC to PCB. Then Check Ohms across the NTC, any idea of the value I should be getting at room temp?
**If I check it in hot water, I should just see a change anyway.
This fault is still intermittent, sometimes it works fine
I have checked these things now.
The wires from PCB to the NTC are fine, all wires are in the loom and clipped along the route, I get 5.1K across the NTC with the machine at room temp and not connected to the PCB. I think its either the pcb or the ntc failing…I only want to buy one of these items though, is it worth checking the pcb for dry joints?
