AEG Lavamat 76810 E70 error
Home Forums Public Support Forums Help And Support Washing Machine Help Forum AEG Lavamat 76810 E70 error
  • #59048
    Needtofixit
    I have E70 error that comes up on all cycles beeping constantly in blocks of 7 beeps. The washing machine appears to still function, however, I cannot stop the error E70 code from displaying or beeping.
    I spoke to AEG who believed the code related to the NTC Thermistor, this sensor is built into the heater element. All the same I swapped this component out and still get the same E70 error. My concern this is a PCB controller fault, but looking at the board nothing appears noticably blown.
    Has anyone else come across this fault and found the fix?
    Controller Card detail is EWS1000 Plus
    Type P451525307 SW Ver W1A30140
    PNC 914 016 192 00
    Looks like a replacement is roughly £140 but keen to avoid paying out if this is not the issue.
    #336612
    Needtofixit
    Re: AEG Lavamat 76810 E70 error
    I was just thinking having read the post “Bosch WFP3300 Fault code F07” although a different manufacturer error code, this also relates to the NTC thermistor. Will double check wiring from Heater element to PCB and report back.
    I have a feeling the vibration of the drum could well have effected the wire to the connector block on the back of the thermistor on element.
    #336613
    Seamy
    E70 is a thermister fault, NTC faulty. You can get this error coming up sometimes if appliance is connected to hot water instead of cold fill.
    #336614
    Needtofixit
    Unfortunately the connector at the back of the NTC was not the problem. I even ended up soldering it to make completely sure. all connectors on the PCB have been pinch together to make a good contact. The washing machine only has a cold water feed, and this appears to be filling correctly, even with the E70 error beeping away. Anymore suggestions or is it swap out the main controller board?
    #336615
    odom
    Did you meter the NTC? What resistance were you getting?
    Have you checked continuity of wires from NTC to PCB?
    #336616
    Needtofixit
    The NTC on old and new element shows about 6.5k at room temp, which steadly reduces as I apply heat, I have also performed a continuity test end to end on the wires, however, I may well replace them just incase there is a break in the wire which only appears when wire is waggled at a certain point along it’s length. Interestingly I have found that I can sometimes stop the E70 error with the selector switch when it is turned off and on and reselect cycle sometimes. But I cannot fool it if I turn the cold supply off to the washing machine and select a cycle. I starting to wonder if the E70 may be related to the water intake. I will not let this washing machine get the better of me ;). Having re-read the basic fault diagnostic page http://www.ukwhitegoods.co.uk/modules.p … ge&pid=353 I am convinced this is not a PCB issue.
    Will take a closer look at cold water fill and re-wire NTC to PCB and report back.
    #336617
    Needtofixit
    Complete confusion !!! NTC rewired checked re-checked and checked again, still getting E70 error with 7 beep pattern.
    If program selector is turned off and a program reselected/started enough times it will not get the E70 error, however, I’m not getting the heater element warming the water during the cycle, which i did have working on at least one 60deg cycle today.
    The machine time seems to go into warp mode and complete the cycle in well under the estimated time too. Ie 80 min (timesaver cycle) will complete in just short of 30 mins and no heating of water.
    No sure what to try next, one possibility is to start testing voltages on selftest, but not sure if self test are done at program selection or when start button is pressed, or when mains power is switched on.
    One last thing to do it to make sure the motor is 100{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} is there a good test link on this forum for checking the windings.
    After that I guess it’s time to reach for new PCB 😕
    #336618
    PCB or bin it are the only 2 options. 🙁
    #336619
    Needtofixit
    PCB has arrived will test this evening (everything crossed it fixes it). But before I do, I just want to check there is not an error code reset on these AEG washing machines, like the one one I found below ???
    Dont want to find out I have fixed the fault by making good the connection to the NTC but just not reset the PCB board.
    NOTE: the C9 on some AEG LAVAMAT models like the 71400, 72600,74620, 86720 and possibly others, is the same as the above F9, and is usually MOTOR BRUSHES WORN OUT. After replacement, you will need to clear the fault indication held in the PROGRAMMER PCB logic: With the Switch in the OFF position – Press and hold PRE-WASH and SOAKING buttons in at the same time, then turn the control knob to Short Spin
    #336620
    Needtofixit
    Update:
    I have tested motor before swapping out PCB and all checks out okay on windings. In addition I have ordered the wiring diagram for this model from AEG only a fiver.
    PCB swapped out…..
    Inital turn on of machine put ELE on the Display and started to fill with water(Oh no I thought!!!)
    I switched off an back on and sure enough we are now fixed!!!
    Okay this leads me to believe there is a reset function on these PCB boards… the ELE more than likely is an intial boot of the PCB short for vendor Eletrolux. Once completed all good. My theory therefore is I may well have cleared an intital NTC issue by my soldering at the begining of this post, however, the PCB may have needed a reset???
    In which case does anyone know how to reset these cards? Ie a combination of panel buttons held in with a certain wash cycle selected???
    At least this will then leave me with a spare PCB board should I ever need it in the future 🙂
    #336621
    caramba
    Hi – I have had a related problem with an AEG Lavamat 62800. Related, in that briefly I experienced the E70.
    From the beginning: over time, the machine (4 years old) began to pause about 20 minutes into a typical wash. For 10-20 minutes, nothing happened at all. It was already at the right temperature, and the fill was right.
    It might restart a while later. More commonly it would display E50 with beeps; sometimes it would jump suddenly, with a screech (I think a motor noise), stop and display E50.
    It was difficult to detect a pattern. Sometimes, especially after a break of a week or so, it might do a pretty normal wash without the pause. Sometimes a different programme would work better. Sometimes I could changed the programme mid-wash and that would get it through. Occasionally it did the pause on a rinse cycle.
    I changed the programme selector. Not very expensive, but obviously not right: no change. I cleaned out all the hosing. The pressure switch seems ok, and there’s never been a suggestion of incorrect fill. The heater seems fine.
    I checked the motor brushes. The motor seems to work ok – when it works. However, part of me suspects some aspect of motor control, because of the pause, and then the jump.
    This week, after reading some online stuff and a manual, I changed the NTC sensor. At first I got E70 sensor code and the 7 beeps, as on here. I managed to clear that just by changing programmes etc.
    But: the previous problem persists. I’ve had the paused programmes again, right away. I changed programmes but could not get it to progress. Finally I shifted it to rinse, it drained and filled, and then paused on that too, for about 10-15 minutes, then suddenly began to turn over again, turned a few times, then drained. On next rinse fill I got the E70 (the sensor fault code); this surprised me as I didn’t expect the programme board to make contact with the sensor during rinse. Then the E70 stopped and the rinse cycle seems to be continuing.
    It’s as if some relay is failing to go over and continue the programme, maybe failing to keep the motor in line. Or, it is the temperature sensor fault and I haven’t got to the bottom of it.
    Any suggestions?
    #336622
    Needtofixit
    Hi Caramba,
    Sounds similar to my issue, which ultimately ended up being the PCB. Going back over the events, there was a trigger to my problem namely overloading the machine with too many towels, which I think must have cause a surge back from the motor and blown part of my PCB. The E70 and the NTC was a red herring as this checked out okay on the AVo meter. I guess the most important thing is to be sure that you still have a good motor before deciding to spend any money on a replacement PCB costing me around 150 nearly 2 years ago, which would go a good way to buying a new machine. Fortunately mine is still working today (lucky gamble) but if you have a faulty motor the last thing you want to end up happening is it blowing a replacement board after a couple of cycles.
    Also worth noting:
    Changing programs as you have done did sometimes mean the the machine would look like it was working, however, it did not heat the water and the wash cycle completed too quickly. Plus
    E70 Errors can show up right at the beginning because the machine does a complete logic circuit selftest before starting the cycle.
    Hope you get to resolve it
    Kind rgds,
    Needtofixit
    #336623
    caramba
    Thanks for the suggestions – appreciated.
