Re: AEG LAVAMAT 86720 fault C3
Not pumping the water out hence C3 f/code? Buzzing or humming too? The pump`s probably seized = either worn out or something has jammed it. Bale the machine out via the door and then investigate via the machine`s pump filter if you find nothing jamming the pump feel how much side shake the impellor ( the propeller, the bit that shifts the water ) has any loose movement and its worn out. From memory those machines have a base fitted making life harder to replace the pump should it be so.To get at the pump to replace it access is via the front panel which can be removed, use decent screw drivers.. The pump is still available both as a pattern or genuine around £30 something and £60 something respectfully..If you need parts everything is based on the 91400???/?? pnc or product code as read off the label as there could be 10 different versions of a L86720.
