AEG Lavamat 86720-W clicking
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries AEG Lavamat 86720-W clicking
  • #6197
    cornwell40
    Hi All,
    Got the above machine and it clicks (Relay possibly?) loudly when it should be filling. Valve is ok so I’m presuming it is some onboard relay??
    Anyone else had this fault??
    Tony C
    #116169
    Re: AEG Lavamat 86720-W clicking
    Tony,
    Did the customer mention an ‘Error Code’ something like “CE” came up at the end last time???
    The ‘clicking’ will be coming from the Motor on the top of the Dispenser. It’s a Motorised Water Distribution system and I find not very serviceable. Better fit a new “Dispenser Top/Motor Assy” Part No: 8996454308306. (They’re not cheap though..about £40. Do check the PNC number to be sure of correct part though 😉 )
    If the machine fails to fill and that thing is clicking on top, then it’s a new one you will need mate 😉
    cornwell40
    Thanks Martin.
    One clickless AEG, one happy customer and one engineer with a 0.05mm thicker wallet 😉
    Tony C
