AEG Lavamat 971 Door release.
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries AEG Lavamat 971 Door release.
  • #43919
    cornwell40
    The door is not releasing via the push button. checked the solenoid on the interlock and its ok. Switch seems ok and connections are ok. Found the wiring diagram for the model and its all in German :rolls:
    Anyone point me in the right direction on this asin the meantime her kitchen needs to be dismantled so I can get the top off. :rolls: :rolls:
    Prod number is 605634119
    TC
    #279039
    rocker
    Re: AEG Lavamat 971 Door release.
    Sure there is a manual release lever, if you open the flap to drain filter. pull down. if that dosent release door, Interlock / release mech possible faulty, if ok you need to check voltage into solonide then work backwards to supply. hope this helps
    John
    #279040
    It’s an old bird you got there TC. Chances are the push button unit is suspect? Also the latch/door striker mechanism worn? HTH? 🙂
    #279041
    cornwell40
    Sorry Gents, missed a vital bit of info there now I’ve re-read it, there is no clunk of any kind from the solenoid but it tests ok.
    TC
    #279042
    usually down to the ribbon cable, where it plugs on to the interlock, often burns its connection. Also wont feed the door release if the pressure switch is stuck.
    #279043
    cornwell40
    Thanks for the help Gents.
    When she rearranges her kitchen I can check all that 😉
    TC
