Re: AEG Lavamat buttons stuck
Thought you’d have banged in a few more for Blackburn this year…. I digress 😆
The switch bank is a “snap fit” into the back of the control panel. The usual reason that the buttons stick is that it will jump out of the clip at one end, jamming the buttons. Best procedure is to dismount the switch completely and see if it’s free. Switch cleaner and a bit of manipulation will usually do the trick if the assembly has actually jammed.
The switch is still listed as a spare if required.
Power off first please…………
