Our AEG washing machine has just developed a fault – it shows error code E20 and does not drain. The filter is clean and there are no kinks in the hose.
We can manually drain using the little drain pipe and then restart the machine and it will continue it’s cycle, until it needs to drain again – repeat!
Any suggestions would be appreciated – it seems to me it must be the pump, but obviously I would like to confirm this before buying a replacement.
Very many thanks in hope
Mike
