AEG Lavamat Error EF0
  • #7330
    I got an AEG Lavamat 72730 update washing machine, and it’s giving me error code EF0 when starting up, It seems to try pumping, but after a while it gives me this error code.
    I does start pumping even with the program switch to the ‘off’ position ?!
    Anyone got an idea what could be causing this ?
    Coen
    #122746
    Re: AEG Lavamat Error EF0
    Coen,
    That error usualy indicates either too much detergent used OR the drain filter being blocked 😉
    The filter seems ok, I checked all hoses, but couldn’t find anything…
    After re-assembling it seems to work fine 🙂
    Hope it will keep working now
    Thanks for your help!
