AEG Lavamat L14850
No: 914605312/01
About 4 times in the last 6-8 weeks there has been an isolated occasion at some stage during a wash or dry programme when the pump has failed to start when required. The result is usually a flashing ‘Err’ message, tho’ I think I once had an ‘E20’ message.
Each time I have drained out whatever water might still be in the drum, removed the filter, found very little if any detritus in there, pushed the impeller round a couple of times by hand, and tried again. In effect, it seems that all it needs is a ‘prod’ and then it’s OK again …for a while.
Is this a symptom of any specific problem?
