AEG Lavamat L 16850 – 91460530902
Home Forums Public Support Forums Help And Support Washing Machine Help Forum AEG Lavamat L 16850 – 91460530902
  • #92820
    petetherev
    Hello, my machine is showing a fault code E73. – Fault in the NTC Sensor Drying Duct (Voltage out of range = Short Circuit Open Circuit) Drying (duct) sensor faulty; Wiring faulty; main circuit Board faulty. Heating is Skipped Start.
    Referring to the AEG exploded diagram
    I have checked the following parts for continuity and resistance.
    Item 48c – Washer Dryer Temperature Probe, No. 3792171203 –
    About 5 ohm at room temperature, functions when heated. Has continuity
    Item 48 – Washing Machine Temperature Probe, No. 8074873012
    6 ohms at room temp. NO continuity
    Item 3 – Washing Machine Manual Reset Temperature Regulator No. 1242702007
    0.3 ohms. Has continuity
    Item 3b Washing Machine temperature regulator No. 1242726501
    I have also removed and cleaned out the Condenser
    I would appreciate any ideas please
    Thank you
    #452297
    Re: AEG Lavamat L 16850 – 91460530902
    item 48 is an NTC you say it has a reading of 6 ohms and no continuity. at 6 ohms its almost short circuit so will have continuity
    correct value should be about 5000 ohms at 20 degrees
    petetherev
    Thanks Dave, I did suspect this part but the descriptions in the parts list sugested tha it was related to the washig, which is working IK, not drying. I have ordered one. I will let you know the result.
    Thanks once again
    Regards
    Pete
    #452299
    petetherev
    Hello Dave, part replaced, all working OK, thanks once again.
    i hope you have a Merry Christmas and happy New Year.
    Regards
    Pete
