Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › AEG Lavamat L12700ViT dryer problem
- This topic has 7 replies, 5 voices, and was last updated 20 years, 2 months ago by
R_Stead.
January 14, 2006 at 3:12 pm #14822
R_Stead
ParticipantMachine is 18 months old, dryer used 4 times, never overleaded, but no longer working. Washing functions are fine.
On removing top cover found belt off what appears to be motor for blowing in warm air. Refitted belt but still not working. Seems that either motor has gone or heating elements may have blown due to overheating if motor stopped, or both have gone. 🙁
Is there a reset switch or kick out relay located somewhere in the machine that I could try? Any advice would be much appreciated.
PS should have mentioned, both dryer settings appear to operate correctly, drum turns, timer counts down normally, no error codes.
January 14, 2006 at 3:25 pm #160909Martin
ParticipantRe: AEG Lavamat L12700ViT dryer problem
When refitting the drive belt does the motor & fan spin very freely I wonder?
January 14, 2006 at 3:43 pm #160910R_Stead
Yes, both spin freely.
January 14, 2006 at 8:41 pm #160911Penguin45
There should be a manual reset thermostat in the top somewhere. Look for a red push button. Power off before sticking fingers in.
If there has been a trip out, it will be because of lack of airflow caused by the belt coming off. A new one is part number 1240827-30/1; an email to spares@ukwhitegoods.co.uk should you wish to order.
Penguin45.January 15, 2006 at 1:52 pm #160912R_Stead
Thaks very much – I’ve ordered the part, and will post update when I have fitted it.
February 8, 2006 at 10:34 pm #160913R_Stead
Ended up calling in an engineer. He said the belt was undamaged, and he got the dryer going, and working OK. Unfortunately after a few minutes the belt worked its way off the spindles. The engineer said he did not understand how the spindles could have got misaligned, and that he does not know how to fix the problem. 😕
Any ideas please?
Thanks again
February 8, 2006 at 11:37 pm #160914macmini
what were the problem with the dryer?
February 8, 2006 at 11:38 pm #160915Dave_Conway
One of the pulleys on either the motor or fan unit are poorly manufactured or misaligned, it can’t be anything else really 😕
Given the little use the dryer has had it all points to a manufacturing defect.
Have a chat with Electrolux (who own AEG):
http://www.serviceforce.co.uk and see if they can help rectify this for you 🙂
