AEG LAVAMAT L74630
  • #14793
    whiskeyjack6058
    Can anyone help me please? I have stumbled accross an AEG L74630 auto PNC 914002097 03 S/N 20376119.
    The fault is: When program is selected, the correct ilumination sequence is displayed. The start LED RED light is iluminated. When the start button is pressed, nothing happens at all. all iluminations remain lit. I have removed the front panel and checked the pump, heater, motor and carbon brushes. On the last run with the machine, it held its water so the customer had to do a manual drain through filter bleed. There are no sigh of any leaks.
    Thank you.
    #160828
    Seamy
    Re: AEG LAVAMAT L74630
    door switch fault perhaps?
    #160829
    What does it say in the display, Jack?
    #160830
    whiskeyjack6058
    this machine doesn’t have a display on the front, so it’s not giving an error code.. Perhaps a door interlock problem… might have to investigate towards lock..
