AEG Lavamat overfill
  • #20593
    Tropicalman
    HI! I am in the West Indies where European machines are rare. My AEG overfills (to top of door), then stops with error code E10. Any advice on what spares I could order to get it going again? Many thanks
    #187635
    Re: AEG Lavamat overfill
    http://www.ukwhitegoods.co.uk/modules.p … ic&t=12318
    Given that the recent AEG machines are tarted up Zanussi product, we can assume that the machine is not detecting the water level. You probably don’t need parts – likely problems are the water level control chambers being clogged up, or split air hose to the level switch.
    Power off if investigating.
    Tropicalman
    Fixed it I think.The level switch has 3 stages and the 3rd was sticking. I loosened the spring tension screw on this & now it works! But I think I should order a spare level switch. Anyway I wouldn’t have even opened the top of the machine without this forum so thanks!!
