AEG Lavamat TURBO 16810 Update – not working, no code
Home Forums Public Support Forums Help And Support Washing Machine Help Forum AEG Lavamat TURBO 16810 Update – not working, no code
  • #51664
    Rudders149
    Hi, can anyone help, my Lavamat Turbo 16810 Update has stopped working, it had started a wash, filled with water, was washing and then started making a constant clicking/buzzing noise. There was no error code shown on the display. I have manually drained the water and emptied the machine, the drum rotates manually with no concerning sounds. The displays appears to be normal in that it comes up with time in mins for each selected program but when you press start, it flashes red then green as if it will start but then makes this awful noise and nothing else happens, the time in mins does’t countdown. I have tried this on a wash, spin, drain etc and each time the same – any help would be greatly appreciated 😀
    #308887
    Flyman
    Re: AEG Lavamat TURBO 16810 Update – not working, no code
    Sounds like something in your pump, rattling around then jamming the pump.
    #308888
    Rudders149
    Great thanks, will have a look tomorrow and see what i can find! 😀
    #308889
    Rudders149
    Can you tell me how to access the pump!!??
    #308890
    Two types of pump fitted to this range.
    The early type has the pump mounted sideways in the middle of the front chassis rail. Access is awkward, but the pump motor can be unscrewed with a bit of patience.
    Late type is a twist fit on the back of the filter housing.
    Power off first, of course.
