AEG Lavamat Turbo 16830 replacement water inlet valve
Home Forums Public Support Forums Help And Support Washing Machine Help Forum AEG Lavamat Turbo 16830 replacement water inlet valve
  • #62105
    newbie77
    Hi, I’ve recently been getting a E10 fault code when putting the dryer on for a second time because it hasn’t fully dried on the first run.
    After looking around on here it seems the water inlet valve is the most likely culprit.
    Could someone please confirm the right part number for it and give me some pointers on how to replace it please?
    Many thanks
    #348681
    Re: AEG Lavamat Turbo 16830 replacement water inlet valve
    The water valve will be this one and it should be fitted at the rear left hand corner (looking from the front), usually fixed with one screw and/or a clip.
    HTH
    rosschitect
    I too need to replace the water valve but the link above is rather generic and gives me search results for ‘aeg’ . What is the correct part number? This model 1249472315 refers to the L16830.
    When I search for ‘aeg inlet valve’ I get various washing machine inlet valves but am not sure which is the correct one.
    Thanks in advance.
    R
    #348683
    There can be more than one, to know you need the PNC number off the rating plate. But, for that model it’s likely to be this one:
    http://shop.ukwhitegoods.co.uk/12494723 … nlet-valve
    Which is the one you found.
