AEG Lavamat Turbo L16830 – E10 E20 Error
Home Forums Public Support Forums Help And Support Washing Machine Help Forum AEG Lavamat Turbo L16830 – E10 E20 Error
  • #95096
    Panthro
    I have an AEG Lavamat Turbo L16830 – which I think has a faulty 3way inlet value or PCB.
    During drying only mode, it will either fail with an E10 or complete the cycle but with water in the drum (so clothes are wet) (looks like the drum water inlet valve is opening at the same time as the condenser water valve so water entering the drum when is shouldn’t be)
    Occasionally, during a wash only cycle, it will also fail with an E20 but there are no blockages and the pump will drain the drum when Drain only mode selected.
    I have also run the diagnostic mode (LED flash round and it shows an E41 error code).
    Has anyone else had such a error/problem combination.. ?
    #459392
    well E41 is just door not locked. you can get that if you start a prog with the door open
    as for E20 its not going to be E20 but will be E21 E22 E23 or E24
    but it does have all the makings of a drain fault. Pump may be intermittent so it wont start sometimes. there may be a temp blockage such as a coin or button that blocks occasionally. It may be an earth fault on one of the elements. It may be a blockage in the pressure circuit that detects water . It may be blocked condenser
