Aeg lavamat W/D L16810 pnc 914601605/02
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Aeg lavamat W/D L16810 pnc 914601605/02
  • #26915
    senseib
    Got this w/d in the other day. Replaced module part no 132122693 but when I tried it just came up with Fault code E90. Cant find this code in “known codes”. I am pretty sure that the new module comes configured. Dont know what the fault is 😡
    Can anyone help ❓
    #211876
    bobokines
    Re: Aeg lavamat W/D L16810 pnc 914601605/02
    I believe that E90 is a communicatoin error. Usually a bad connection between the two boards.
    Bob
    #211877
    senseib
    Thanks Bob for your help. Checked all connections seem good!
    When i put old module back on m/c and turn indicator to long spin:- 1600 spin speed light lit, door light green, digital display flashing 12 (mins presumably) & spin light lit. When i press start button:- one click & door locked green light goes out, display still flashing 12 nothing happens!
    If i put new module back on display flashes E90 😈
    #211878
    rogue_element
    MAY BE WRONG FAULT CODE
    FAULT CODE ON WHITE STICKER ON PCB HOUSEING
    HOPE THIS HELPS
    ROGUE
    #211879
    dpm
    You *sure* it’s configured? Might be worth checking the code’s right.
    #211880
    senseib
    Just checked! & apparently this module 1321132803 comes unconfigured 😈
    Really p~##ed off with modules that come unready for use – especially those without instructions on how to get them ready 👿 Pretty sure everyone else is too!!!!
    Can anyone tell me how to configured this one please ???
    Brian.
    #211881
    senseib
    Sorry meant module 1321226936.
    Brian.
