aeg lavamat W1059
  • #57463
    mike100
    Wont do anything except end button flashing 5 times.
    Can’t see that in uk fault code guide.
    Its got an AKO 547703 module if thats any help.
    Mike
    #331137
    Re: aeg lavamat W1059
    Can you give us the full PNc number of the machine?
    #331138
    mike100
    pnc 914 002 452 00
    #331139
    fault 5 is motor based
    motor traic short
    no signal from triac
    motor traic sensing circuit faulty
    motor relay contact sticking
    to find which one you have to go into diagnostic mode
    check motor for earth faults had this fault once and motor was wet
    mike100
    Thanks Dave going back to check.
    Mike
    #331141
    mike100
    Dave,
    You were right motor going to earth.
    Put in used one, job done, thanks.
    Mike
