This machine has done years of hard graft. Over the years I’ve rplaced the pump, done brushes, door latch, seals, bearings, … would be great if I can sort this issue.
IthHas what I would describe as a power fault. At a random point during a cycle it will power off completely. All LEDs go out. Its as though the plugs been pulled.
If I switch contol dial to off position. Switch it off at the mains for 20 mins then when I power it up it will work again and I can start the cycle again.
This fault used to happen occasionally but has become more common over time. Now its rare that it will finish a cycle.
Any suggestions? Replacing main PCB would likely fix it but is there something I can try first? I know how to use a multimeter and soldering iron. Happy to give anything a try!
All and any help very gratefully received 😉
