AEG Lavamat W1259 electronic. Weird fault?
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries AEG Lavamat W1259 electronic. Weird fault?
  • #33382
    whiskeyjack6058
    Went to one of these machines today. Customer reports that it wont spin and the ‘end’ led flashes. Did my usual routine check, started by trying it on a spin. Machine pumps out fine but appears to have no motor action. After pumping out long enough to empty the tub, the machine goes dead for about 1 min, then begins to pump for aprox 5 secconds, goes dead for another min, then pumps again for another 5 secconds. I assume it then repeats this process until the end light begins to flash. So, tried it on a 40o Non fast coloureds. Machine fills up to the usual level and the drum begins to turn with the normal wash action. after a short display of motor action the machine becomes inactive. PNC is : 914 002 451 and S/N is : 32780846. Not had this one before. Could it be a faulty PCB perhaps? Any feedback would be deeply apriciated!
    WhiskeyJack6058
    (Robert)
    #238467
    aqualectric
    Re: AEG Lavamat W1259 electronic. Weird fault?
    Hi Robert,
    Check your E’mail. 😉
    Hope that helps,
    Steve.
    #238468
    whiskeyjack6058
    Thanks, had a look at that. Complicated stuff… Well, will try and read the error code. Any more help would be welcome.
    Thanks,
    Regards
    Rob.
    #238469
    aqualectric
    Sorry, Rob – I forgot to send the flow chart diagnostic sequences. 😳
    Another e’mail for ya.
    Look at E52 – probably where you need to test.
    Steve.
