Hi Folks
Just like a few oppinions on this one if you can
Machine starts pumps out for about 10 secs then shuts down. Gone into diagnostic mode and comes up with an E45 fault which according to manual is a pressure sensor fault.
Pressure sensor looks like an electronic presure switch? Tested between all three contacts and got a resistance between but presumably as this is a variable resistance the resistance should be high which it is.
Has anyone had any faults with these or as I am getting a resistance between contacts is the fault more likely to be the pcb board?
Put machine onto all the other function modes in diagnostic and all componants are working including motor on the leak testing cycle but machine won’t go into spin on pump and spin test, will only pump out then shuts down.
Any ideas?
