AEG Lavatherm 360 belt replacement
Home Forums Public Support Forums Help And Support Tumble Dryer Help Forum AEG Lavatherm 360 belt replacement
  • #101742
    SJMorris
    Hi. Need to replace belt. Have sides off. Presume I need to feed belt over a gap created between door and drum and to do that looks like I need to remove the top. Removed screws at back and nudged top forward an inch or 2 but seems connected about six inches from front and I can’t see how to release it. Appreciate advice on how to do that and any further advice about replacing the belt. Thanks… S
    #485891
    andyjawa
    AEG 360 No idea. Your best bet is tell us the pnc / product code number so we can see the break down to advise you. Normally with AEG /Zanussi you attack the machine from the back to replace the belt and not from the front. But would need the proper info to be sure.
