Home › Forums › Public Support Forums › Help And Support › Tumble Dryer Help Forum › AEG Lavatherm 37700 (c. 1999) running hot
- This topic has 5 replies, 2 voices, and was last updated 3 years, 6 months ago by
IC WG.
September 19, 2022 at 5:33 pm #101179
IC WG
ParticipantHello all
Our 20+ year old AEG vented dryer had a couple of sessions where it smelt like it was running very hot. The load wasn’t unusual and no obstruction was visible where the vent emerges outside.
I stripped it all down and gave the lower part of the casing which has 3-way vents a good clean and wash out. I’d previously given the vent box a vacuum out a couple of years ago. Overall there was remarkably little lint, dust, etc anywhere and none at all that I could see in the heater air duct, element, etc.
As far as I could tell there was a thermostat in the heater assembly and one in the channel leading from the door lint filter duct. I’d expect these to be fail-safe, so any problem would cause lack of heat rather than excess. Can they fail in a way that can cause overheating?
I’m wondering if I missed some components though as I thought there was a humidity sensor that helps set the “machine iron” to “extra dry” load condition LEDs on the front. Didn’t see it though – is there not one? Only other clue to any problem I can offer is that when putting a test load in that had got quite dry on the line outside I expected those LEDs to quickly jump to “hand iron”, etc – but they didn’t.
A couple of cautious drying sessions since seem to have been OK, but we’re trying to get back to not popping in to check on it every 5 minutes.
I have a multimeter and hot air gun that I can use to test hings if needed. Hints and tips welcomed.
September 19, 2022 at 9:30 pm #483710electrofix
Moderatortried to look it up but the model is incomplete
are there any other numbers like a pnc number ?
September 20, 2022 at 8:43 am #483711IC WG
Participantelectrofix wrote:… like a pnc number ?
Thanks. PNC is 916 011 077 02.
I’m becoming more convinced it is the dryness sensor side of things that is problematic. I put a damp towel in last night and while there was no overheating odours it just kept running on initial / default programme countdown. No jump in timer when it realised it was a small load, and no lighting of the dampness / ironing LEDs even though towel was fully dried.
September 20, 2022 at 9:43 am #483712electrofix
Moderatorok that makes more sense
full model no is LTH37700
overheating problems are often the front stat
the dryness is set by a conductivity sensor which consists of 2 brushes running on the drum to 2 electrodes that should be electrically isolated
check brushes and isolation
September 20, 2022 at 5:02 pm #483713IC WG
ParticipantMany thanks, that helped me find the problem.
There is just one brush which is on a hinged PP mount with a spring to pull it on to a special looking band of metal the drum, AEG part 647 071 680 on the diagrams I found, leading to this: https://www.mijnonderdelenhuis.nl/ae…470716805.html
The hinge was nearly fractured, but the remaining thread of plastic had allowed the brush to twist and drag on a different part of the drum – so on first inspection all looked well. I’ve now bodged the hinge with adhesive tape to see how things go for while. Initial test good – ran dryer empty and it turns off after a few seconds as it can now detect there is nothing to do.
If anyone on the forum can supply that part ex-UK feel free to let me know :).
September 20, 2022 at 5:33 pm #483714electrofix
Moderatorpart no 8996470716805
AEG are showing as not available but gives a number to ring
https://shop.aeg.co.uk/search?q=:rel…nc:91601107702
the website you listed above lists no stock either
