I’m getting error code E10 after a couple of minutes of starting a drying cycle. Comments on other forums suggested the three way solenoid valve feeding the condenser, I have checked the resistance of the coils, two are 3.6K one was 5.5Kohms, should they be the same? Can I test the solenoids by applying voltage across the pins? (mains or low voltage DC?). Other suggestions?
