Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › AEG LAVW1050 91400242400
- This topic has 10 replies, 4 voices, and was last updated 19 years, 5 months ago by
Alanj.
November 10, 2006 at 9:52 pm #22455
Alanj
ParticipantHi Guys,
got this machine Initial fault was end light flashing 5 times first phase then 4 times in steady sequence. When I checked the fault code by holding the top two buttons on the first bank of switches the sequence gives a fault code of 43 which is supposed to be the door interlock. I changed the interlock and got the machine to come back to life, but now if I select the spin program the machine starts by pumping out and then does one cycle of motor action,pauses as if it is going to change direction and then the machine goes silent, no pump,no motor but the program lights are still on. switch off and back on and fault as before. If I disconnect the motor I can reselect the program and restart, plug the motor back in and the fault resumes. anyone know if this is likely to be a module or motor fault. Have only checked machine on the spin prog.
Alan
November 11, 2006 at 12:35 am #195037Penguin45
ParticipantRe: AEG LAVW1050 91400242400
Mail……..
November 11, 2006 at 9:45 am #195038Alanj
Thanks for the mail Chris, but I have have this info,just wanted to know if anyone had a definite diagnosis between motor and module.
Alan
November 11, 2006 at 10:18 am #195039Alanj
Chris,
ran the full service program, it wouldn’t start with the motor plugged in,worked ok without motor plugged in, plugged motor in during test and error code 51 came up, so assume it’s the motor?Alan
November 11, 2006 at 10:40 am #195040Alanj
anyone know where I can get a motor cheap?,it’s for my own machine.
A new one is £99.00 + vat.Alan
November 11, 2006 at 2:52 pm #195041admin
Keymasterfor checking motor you have to measure his resistence between plugs… brushes, stator and tacho… and most important measurement is from each of them to mass on MOhm scale
November 11, 2006 at 3:38 pm #195042cab
Hi code 51 is pcb fault, triac which controls motor!
cab
November 11, 2006 at 5:48 pm #195043Alanj
Baron
Can you repair pcb by changing faulty triac. Is it the one clipped to the heatsink.
Alan
November 11, 2006 at 7:38 pm #195044admin
KeymasterAnything can be repaired… only life not… and depends of costs…
If I remember is BTB16 but I thing is not that faulty… few of them is gone “lazy” more are going in SCC and then motor is starting to spin all time…To be more accurate tell me what kind of PCB has: EWM1000, EWM2000, AKO… or more rapidly layout photo…
November 13, 2006 at 8:17 pm #195045Alanj
Hi Baron,
it’s a AKO 547.703 Lux Code 132148310 Firmware ver.W1D00109
Alan
November 15, 2006 at 8:11 pm #195046Alanj
Hi Guys,
Thanks for all your input with the problem I’ve had with this machine.
I finally pinpointed the fault, it was the heater ntc that was faulty.Machine going great again.Thanks again
Alan
