AEG/Lux W/Dryer E10???
  • #52265
    Not been out ot this one yet.
    Pnc. 914602122-01 Complaint of drying problems, says display shows E10.
    Just had a look at the error codes and cannot see E10. 😕
    Any ideas?
    Re: AEG/Lux W/Dryer E10???
    I think that’s the green dryer solenoid coil which goes open circuit after ten minutes operation.
    Mike.
    #311141
    timdowning
    Jim, search zanussi AND e10.
    That should do ya.
    #311142
    helo_75
    just change the green coil, and clean the condenser… job done
    #311143
    DOH, I seem to remember doing one of these solenoids about three years ago, it was a much older model though and didn’t have a digital display, seem to remember it stopped the wash heater working on that one. 😕
    Thanks for the info chaps, will attack it with confidence. 8)
    Just got a call back to this beast this afternoon. She says it is now bleeping and showing E20…….but only on the drying programme, washes and spins fine. 😕
    Diagnostics throws up E22. Checked everything I can, dryer heater, both pressure switches, pump, filter outlet hose etc.
    Set it to dry and it ran perfectly for fifteen minutes, she said it usually knocks off after only two or three minutes on the drying cycle.
    Changed the fill valve in Feb to cure the E10 fault.
    Any suggestions?
    bigchrisoioi
    e20 0n dry only > CHANGE THE CONDENSOR OR CLEAN IT TO AN INCH OF YOUR LIFE lol…….honestly it is easier and no expensive to swap the condensor…always e20 on dry only this one!
    #311146
    Will check it out the next time she calls, thanks.
