Hiyas,
I’ve got an AEG microwave giving error code E14. Can’t find these error codes at all. Model is EH8735 , E Nr. 947003003.
Anyone know these codes? Also, anyone got a wiring diagram for this?
Its an error of the damper motor, the little motor that closes the flap. needs to send a signal back to the board when open or shut by microswitch usually.
Quick update on this one. Went back today armed with the circuit diagrams.
Found one of the pins on the new board missing, soldered in a pin from the old board, plugged it all together and it worked.
Thanks for the help Mark, the diagram made the job so much easier.
