I have the above sat in my workshop.
Model 50700-w
PNC 911 232 407 01
S/N 12076882
When the dishwasher begins to fill up a small amount of water begins to run out of the clear plastic breather pipe fitted to the plastic water box/regen unit on the left side of the dishwasher. Over a short period of time, this fills up the base and puts it into flood protection. There is a thick black hose that seems to be connected to the sump. I have checked this to see if it is made up with any blockages but it seems to be clear.
There is a bit of a ‘crud’ build up inside the water box but I didn’t want to remove it or replace it until I have a bit more info on this. I have had a look at the electrolux website using the pnc number and it gives me no info on this problem. There must be someone out there who has had this before.
Any ideas guys?
Many thanks,
Rob. (WhiskeyJack6058)
