AEG Oko-Lavamat 1271 VI Turbo – not completing cycle
Home Forums Public Support Forums Help And Support Washing Machine Help Forum AEG Oko-Lavamat 1271 VI Turbo – not completing cycle
  • #52669
    CarlaOL
    Yesterday I did a load of washing and it worked fine. Well, I think it did, it was the first time I decided to use the dryer for 15 minutes, but when the machine beeped saying the program was done the towels didn’t seem any drier than usual.
    I then started a second load and when I looked at the machine after a while as it was unusually quiet, the timer showed the number 1 and nothing was happening
    the washing had not been done by any measure as the detergent gel was still there on the machine’s drum. there was some water in the bottom of the drum.
    I put the switch on reset, opened the door and removed the clothes.
    Then we tried the ‘pump out’ and the machine kept going to 1 and the light on to prewash and not functioning. There was no error message/code
    After hitting reset for a while, we managed to do a pump out until the end.
    thinking the machine was working we put the clothes back in and again it looked like it was going to work for a few minutes (2 or 3) minutes and then went back to 1 and prewash light and not working.
    It seems to regularly do this now, we managed to do another pump out and then a short spin to remove the clothes from the machine so they would not be dripping. we have not tried it again.
    I then turned it off at the mains, and left it to rest.
    Does anyone have any clues on what the problem is or what could be done before we have to call a plumber in?
    I am tempted to do an empty cycle with some vinegar in to see if it works…
    Is this a bad idea?
    #312672
    CarlaOL
    Re: AEG Oko-Lavamat 1271 VI Turbo – not completing cycle
    And just now after leaving it off at the mains overnight, i tried to do a 95 degree wash with vinegar and it worked ok (filling with water and spinning) for about 50 minutes (when i started the panel indicated 2.29 and the last I saw had 1.40
    Then it went back to 1 on the panel and the light is on wash. And the drum is full of water.
    I wonder if it stops when going to rinse.
    I am trying to do a pump out and it keeps pumping out a very small amount and then stopping and the panel goes from 5 to 1.
    Help!
    #312673
    Simon46
    Have you checked the filter? Should drain on spin within 40 seconds. make sure water is out of drum before opening. Towels down as well.
    S.
    #312674
    CarlaOL
    thanks, i have.
    the filter had a bit of gunk and hair which i have cleaned yesterday, but today the problem was still there
    #312675
    CarlaOL
    this evening we tried to replicate the problem as we have someone coming tomorrow.
    we did a cold wash with the machine empty and it all worked fine
    then we did a 30 degree easycare wash with probably half a load and it worked again
    Should we cancel the person coming?
    Could I have over loaded the machine on saturday and it took a while to get back to normal?
    any ideas?
    thanks
    #312676
    patchitos
    hi….i am having the exact same problem with my aeg 1271 machine…did you ever find the problem?…thanks…john
    #312677
    CarlaOL
    4 years on the machine works fine. I never tried the drier again though and remember to put the dial on reset between each load…
    #312678
    patchitos
    hi…thanks for your reply…mine seems to be working ok now..washer and dryer..i think resetting between cycles has a lot to do with it…thank you
