Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › AEG Oko Lavamat 16800 – Won’t tumble dry
- This topic has 7 replies, 4 voices, and was last updated 20 years, 4 months ago by
Laserlight.
December 19, 2005 at 9:05 am #14145
Laserlight
ParticipantDuring a tumble dry cycle the E10 signal came up. a problem with water supply according to the handbook. We started the cycle again and got the same result.
I ran the machine in normal wash cycle which worked fine, no problem with water supply.
I then started the machine in tumble cycle, this time the pump cut in as normal but then the machine rotates the drum one way a couple of times, stops then does the same in the other direction, this continues without change (I had left it doing this for at least 15 min). During this time the LED “cycle time remaining” counter remained fixed not changing.
I then started the machine in normal wash cycle and turned the water off, this did not produce the E10 signal this time.
Can anyone point me in the right direction? 🙂
December 19, 2005 at 1:08 pm #158338Dave_Conway
ParticipantRe: AEG Oko Lavamat 16800 – Won’t tumble dry
Laserlight wrote:Can anyone point me in the right direction? 🙂
Yep, check the inlet valve as the dryer uses a different part of it from the wash cycle 😉
Power off please when checking :zap:
December 19, 2005 at 7:52 pm #158339Laserlight
ParticipantThanks for that, will investigate tommorrow.
December 20, 2005 at 4:25 pm #158340Laserlight
ParticipantOK, I’ve looked at this but decided not to dismantle the valve just yet just in case I break something and then not be able to wash anything (family of six, can’t not be able to wash)
Can you tell me what does water inlet have to do with tumble drying?
Which part of the valve relates to the tumble function?
If I replace the valve with a new one will the machine require resetting by an Engineer?
Thanks in advance
December 20, 2005 at 4:28 pm #158341Martin
ParticipantLaserlight wrote:If I replace the valve with a new one will the machine require resetting by an Engineer?
No! a new valve will cure this fault 😉
December 20, 2005 at 4:36 pm #158342Dave_Conway
ParticipantDecember 20, 2005 at 9:30 pm #158343Penguin45
Can you tell me what does water inlet have to do with tumble drying?Have a read of this:
http://www.ukwhitegoods.co.uk/modules.p … age&pid=52Regards,
Penguin45.December 22, 2005 at 7:08 pm #158344Laserlight
ParticipantThanks for that Penguin45, youv’e made me a wiser man.
Thanks also to Martin and Dave Conway. I’ve been telling all my friends about this site. Very helpful, much appreciated. 🙂
