AEG ÖKO LAVAMAT 41150, Error Code E04
Home Forums Public Support Forums Help And Support Washing Machine Help Forum AEG ÖKO LAVAMAT 41150, Error Code E04
  • #25891
    vito
    Power comes up, panel leds works, but washer dont start at all.
    Brushes are good conditions, water inflow and outflow pump works too, i removed both pump out, and i test it with electric
    It doesent take water or do anything, panel leds works it shows washing time and everything normally, and its kilicking normally knack knack, but nothing wont happen..
    What that error code means E04
    Thank you for answers.
    -Vito-
    #207984
    Re: AEG ÖKO LAVAMAT 41150, Error Code E04
    This doesn’t appear to be a UK machine – can’t find anything on it. How old is it?
    Most newer AEGs use Zanussi electronics – they don’t have an E04 – there is an E40 code though?
    vito
    Im not sure in age but i think its about 5-7 years old
    Its same like this.
    http://www.kodukaubad.ee/?l=ee&show=1&i … 1&firm=AEG
    #207986
    vito wrote:Power comes up, panel leds works, but washer dont start at all.
    ……. and its kilicking normally knack knack, but nothing wont happen..
    -Vito-
    I just ask you what do you mean “Knack Knack”? where she do that?
    Did you read correctly “E04” or is like Penguin45 ask “E40” or is “EOb“? 😯
    Which Led’s are flashing (from wash phases column) when shows your error “E04”? :rolls:
    Baron 8)
    #207987
    And have you PNC or E-nr…?
    #207988
    vito
    E-nr number is 913729151.
    And i mean that sound, like is try to do something, klicking the control panel that normal sound when washer is starting…
    Power button flashes, but if if i push that button again the power button lihgts normally.
    #207989
    vito
    Okay i get it user manual for this machine
    E04 means that you have choosed wrong wash program.
    But still it dont works anyway…
    What might be a problem? im thinking program card…
