AEG Oko-Lavamat 6350
  • #14082
    MikeyB9
    E no. 605 647 514
    F no. 126/749091
    I have had this machine for 9 years and this is the first time it has needed any attention.
    The machine has started tripping the main circuit breaker in the consumer unit, so obviously there is current leakage to earth.
    The machine works perfectly when the temperature dial is set to cold wash, or if you select spin only etc.
    When a temperature other than cold is selected the machine trips the circuit breaker about 15/20 seconds after the on button is pressed.
    I have checked the motor brushes and blown the carbon dust out of the motor – all OK and no earth leakage, brushes still have 20 mm sticking out of holder.
    The resistance across the heater element is 23 Ohms with no short to earth.
    I have disassembled the thermostat/switch assembly – all appears well no signs of arcing or burnt contacts etc.
    I cannot see any signs of arcing or wiring chafing anywhere.
    I am reluctant to call an engineer and pay the call out charge, only to be told that the module or something else expensive needs replacing – I would rather put the money towards a new machine.
    Am I also right in thinking that this machine does not have a diagnostic function, so unless it is something obvious or the engineer has seen this before I may get into an ad hoc replace parts scenario.
    If anyone could point me in towards any other checks I could make I would be very grateful as I would like to fix this machine if economically viable.
    Until the other day it has been fantastically reliable and has performed faultlessly for 9 years.
    Thanks in advance
    Mike
    #158019
    Re: AEG Oko-Lavamat 6350
    Got to be the heater at fault Mike, have you tested it with a 500volt insulation tester or just a multimeter? Easy way is to disconnect the leads to the heater, insulate them out of harms way, then try the machine with the t/stat set on any temp. “If the trip don’t blow its the heater you know” 😉
    #158020
    MikeyB9
    Hi Martin,
    Thanks for the quick reply.
    I did what you suggested, and the circuit breaker didn’t trip this time, so it looks like I need a new heating element.
    Can you give me the part number and the price please?
    Many thanks
    Mike
    #158021
    part number for genuine part is: 89 9645 42 50-06/0 although there are cheaper alternatives availble,
    email spares@ukwhitegoods.co.uk
    and i am sure a nice helpful person will sort you out.
    #158022
    Dave_Conway
    Thanks Mark, I’ve added it to the shop as well for you if you’d rather order online 😀
    Please click here
    #158023
    MikeyB9
    Thanks for all your help.
    I got a new element locally as I needed to have the machine back in action ASAP.
    All is now working fine.
    Have a good Christmas.
    Mike
    #158024
    MikeyB9 wrote:All is now working fine.
    Merry Christmas to you too Mike, glad to be of service 😀
